Adjustable Shocks
Old May 4, 2004 | 04:02 PM
jstkrsn's Avatar
jstkrsn
Default Adjustable Shocks
Was thinking about changing the shocks. A friend said the Bilstein Z52 shocks with the stock springs works real well. But I like the idea of adjustable shocks I can change from cruising to road racing. I like the idea of the electronic ones I don't have but that's too costly to add, but what about the Koni Adjustable ones. I found them for $528 shipped so far.
jim
Old May 4, 2004 | 05:14 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
Default Re: Adjustable Shocks (jstkrsn)
Koni are a great shock, but in order to adjust the rears on the car you'll need to drill a hole in the frame from the inside of the car.
I went with the HAL QA1's, been working great.
Old May 10, 2004 | 12:32 AM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
Jim,
I had just put the new KONI Sports (adjustable) on my C4 before Saturday's SCMR13. You and I talked briefly about them at lunch, but I didn't fully appreciate them until the after-lunch drive was over.
I love 'em.
If you decide to get them, IM me and I'll tell you where I ended up with the settings...maybe I can save you pulling the rears off for adjustments.
By the way, you didn't seem to have any problem keeping up with me with your old shocks!!
Larry
code5coupe
:seeya
Old May 10, 2004 | 03:08 PM
jstkrsn's Avatar
jstkrsn
Default Re: Adjustable Shocks (rocco16)
It was good meeting you Saturday. Changing the shocks isn't really on my list of things to do immediately. I think about it every time I go on one of the mountain cruises. But I like the idea of being able to adjust them to the type of driving I would be doing at the time. I'm sure I'll be seeing you again at a future function and we can discuss it more.
Thanks again.
Jim
Old May 10, 2004 | 07:33 PM
BAM92's Avatar
BAM92
QA1's are adjustable and have a external dial on the lower side of shocks. 14 settings. You can buy them from Jegs.
Old May 11, 2004 | 01:56 AM
nonetooclose's Avatar
nonetooclose
Default Re: Adjustable Shocks (BAM92)
How are the QA1's? Are they any good? Would you rate them better than the Edlebrock IAS for an 85?
Old May 11, 2004 | 02:02 AM
rsafier's Avatar
rsafier
Default Re: Adjustable Shocks (nonetooclose)
I have had QA1 on two Vettes now. Great shock. Koni's are also great, but do require removal of shock or modifing the frame some in order to adjust them. Think they are probably about equal. If your looking for that last little bit Koni's might work better for you simply because more guys at the national level run them so will know what settings to use, and if you want custom valving I think more places will be farmiliar with Koni's then the QA1s.
Also I believe its only 12 settings, not 14. At least mine were not 14.
If you happen to get them, I find 4 all around is a nice setup for street driving.
I ran 8 in front, 5 in rear last autocross. I find being a little soft in the rear works out nicely for controlling oversteer.
Old May 11, 2004 | 02:10 AM
nonetooclose
Default Re: Adjustable Shocks (rsafier)
Awesome! This is the information I needed since I have not heard a tremendous amount of information about the QA1s, and was a little leary of buying shocks that I have not heard too much about.
Richard
Old May 11, 2004 | 10:58 AM
jstkrsn's Avatar
jstkrsn
I looked into the QA1's and they sound like the way to go. Found them for $556 at NAAKE. They have 12 settings as you said. Thanks for your info.
Jim
[Modified by jstkrsn, 9:59 AM 5/11/2004]
Old May 11, 2004 | 06:11 PM
BrianCunningham
I actually run QA1's on my car.
Love'em! :thumbs:
I autocross, drag race, road race, and run them on the street.
The adjustability is great. Don't even have to pull a tire, just reach underneath.
Old May 11, 2004 | 07:28 PM
BAM92's Avatar
BAM92
Default Re: Adjustable Shocks (BrianCunningham)
Sorry, I meant 12 settings. These shocks seem to be the best of all worlds. You can have a nice cooshy ride then change them, quite easily, for auto crossing or even drag racing. I will probably go with these before end of year.
To Adjustable Shocks
