Going nuts
Old May 4, 2004 | 07:58 PM
95Redcoupe's Avatar
95Redcoupe
Default Going nuts
OK
Heres what's going on first I had a water pump leak now an oil leak but not sure where its coming from I still I have front apart water pump off, opti out. I am now think of changing seals and gaskets on timing cover. If I pull of the hub that holds balancer on can I replace seals without taking off timing cover?
Or just go for broke and drop oil pan? It might be leaking from there, it only seemed to leak when car was parked with front facing down hill. Is taking pan off a pan this is an automatic. And I only have ramps to work with for height.
Sorry for all the questions
Thanks in advance
Rich :crazy:
Old May 4, 2004 | 08:02 PM
CFI-EFI's Avatar
CFI-EFI
Default Re: Going nuts (95Redcoupe)
I'd start backing in to those parking spaces.
RACE ON!!!
