Will these wheels fit?
Old May 5, 2004 | 01:12 AM
95_6spdvette's Avatar
95_6spdvette
Default Will these wheels fit?
Ok I have my mind made up on these wheels but im not a wheel expert and dont know anything about backspacing or the offset. I sent to the company and this is what they told me.
"We offer for your `95 C4 Corvette the ROH RT Black Ice 17x9 5x4.75" bolt pattern +43mm offset / 6.7" backspace and a 18x10 5x4.75" bolt pattern +49mm offset / 7.4" backspace"
So will these fit or are they gonna stick out to far or not far enough is my question? Thanks for the help
Old May 5, 2004 | 01:28 AM
BAM92's Avatar
BAM92
Default Re: Will these wheels fit? (95_6spdvette)
GS wheels have a 17x9.5 front with a +56 offset. The ROH wheel is a 17x9 with a +43 which will make it right at the fender. I have 18x9.5's with +48 offset and they are right at the fender. On the rear, the GS's have 17x11 with a +50 offset and stick out more than 1/2 inch. The ROH wheel with 18x10 and +49 offset will be in the fender well no problem. Just remember the greater the + offset the deeper the wheel goes into the fender well. So yes they will fit.
Old May 5, 2004 | 02:13 AM
DieL's Avatar
DieL
Default Re: Will these wheels fit? (BAM92)
the gs wheel with 50mm offset Will NOT stick out 1/2 inch. the zr1 11 inch wheel with 36 mm offset will though. just clarifying.. :)
Old May 5, 2004 | 05:41 PM
BAM92's Avatar
BAM92
Default Re: Will these wheels fit? (DieL)
The GS wheels with 315's I had stuck out about 1/2 inch. If I put the ZR1 (+36.5) offset it would be closer to 1 inch. My 18x11's with a +59 offset stick out less than a 1/4 inch on both sides.
To Will these wheels fit?
