max lbs. boost on p600b?
Old May 6, 2004 | 02:07 AM
Gold nugget's Avatar
Gold nugget
Default max lbs. boost on p600b?
Whats the highest lbs. of boost have you got from your p600b.? On an L98
Old May 9, 2004 | 04:25 AM
Jaxian's Avatar
Jaxian
Default Re: max lbs. boost on p600b? (Gold nugget)
Been a while since my car has run but as I recall with my slightly warmed over stock motor, (cam,ported heads,exhaust,siamesed runners, ported plenum) using the 12lb pulley I can't remember ever seeing over 8 or 9 psi. I remember calling ATI when I first got my boost gauge, and yes I was annoyed after spending $4500 on one of the first vette kits made that it didn't have a boost gauge, they said it was because my engine was modified and the reduced back pressure wouldn't let it hit full boost. Sounded like a easy tech support answer to get people off the phone but at the time, which was around 7 years ago I didn't know any better. New motor is in but not running atm so not sure what it will do boost wise now.
Old May 9, 2004 | 04:57 PM
Gold nugget
Default Re: max lbs. boost on p600b? (Jaxian)
I've been running 10lbs for 2 years on stock engine and boost gauge reads 8 lbs. Going to build lower end and what to raise boost higher. Talked to a tuner last year that claimed to run 15 lbs. Not sure how he did this. Lost his number.
Old May 11, 2004 | 10:03 AM
SBNova's Avatar
SBNova
Ive got a 10lb pulley/kit and I see almost 9lbs with my autometer gauge. Never higher though...
Old May 11, 2004 | 04:45 PM
pffsvette's Avatar
pffsvette
I went from a 4.0 pulley to a 3.6 on a L98. It increased boost from 5-6 to 9 lbs. but my engine was old enough that it could not take that much boost. ATI told me that any more boost on a stock L98 would do damage.
Old May 12, 2004 | 10:08 PM
AKS Racing's Avatar
AKS Racing
Default Re: max lbs. boost on p600b? (SBNova)
I pulled up some old details of a combo I ran back on a 11.4:1 SCR 350 ci with a large cam, 215cc intake runner heads, ported SR intake, and a 58MM TB. I ran the 2.8 pulley and got like 5.5 psi. Stepped up to the 2.55" blower pulley and got 8.5 psi at 5600 RPM (car made just over 550 RWHP). Just before I changed out the motor and went to a D-1 and a built motor, I pulled the 5700 chip from the MSD and installed a 6200 chip. Ran the motor to redline through the gears (kinda forced it) and found 11 psi.
According to ATI (which if you believe them ...), a 350 stock motor with the 2.55" pulley will make ~22 psi. Yeah right, but it was an interesting point of comparison. Prior to the blower, the car ran 11.9 with a 1.5 60'. Best time with the P-600B was 11.1 @ 128 on slicks.
I did not trade out the P-600B because it broke, I just wanted to do something different with the combo. The D-1 only lasted a short time and then switched to the R version and the other car runs the D-2R. Be careful of getting addicted to this stuff.
Aaron
Old May 18, 2004 | 01:53 AM
Gold nugget
Default Re: max lbs. boost on p600b? (AKS Racing)
Thanks for the replies.
To max lbs. boost on p600b?
