under drive pulleys gains
Old May 6, 2004 | 10:28 AM
redvette6spd's Avatar
redvette6spd
Default under drive pulleys gains
i am planing on doing bolt ons on my stock 91 i was thinking about under drive pulleys are thay worth the money what are the hp gaines also whare to get get them at a good price thanks
Old May 6, 2004 | 10:43 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: under drive pulleys gains (redvette6spd)
You can expect 5-10chp gain.
Summit has the March Power & Amp series. I only installed the underdrive crank & over drive alt pulleys from the set. Though I got the steel set I'm thinking that the Al set might give a little better gains.
Have you done the "free" type mods yet?
Old May 6, 2004 | 10:59 AM
redvette6spd
Default Re: under drive pulleys gains (65Z01)
car is going to shop this weekend has k&n and open air box doing tpis long tube headers gutting cats magna flow cat back air pump eleminator frizbe toss clean up pluntum tpis prom gas regulator
Old May 6, 2004 | 11:31 AM
65Z01's Avatar
65Z01
It should be like driving a different car with those mods.
Have you considered an AFPR to add more fuel at WOT by bumping fuel pressure? Those serious air flow mods may need a little more fuel.
Old May 6, 2004 | 01:53 PM
redvette6spd
what is a AFPR i thought a adjustable fule regulator takes care of fule preasure
Old May 6, 2004 | 01:56 PM
redvette6spd
bad speller fuel,fuel :_dupe:
Old May 6, 2004 | 02:11 PM
vader86's Avatar
vader86
AFPR=adjustable pressure regulator
most people show a .1 gain from the underdrive pulleys, so its about 10hp
To under drive pulleys gains
