J55 Brake upgrade
Old May 6, 2004 | 04:21 PM
mik's Avatar
mik
Default J55 Brake upgrade
I have a 94 with the standard 12" brakes up-front. I am considering upgrading to the 13" J55 brakes. Do the J55 calipers, caliper brakets, and 13"rotors bolt directly to the standard front-end spindles or are adapter plates required?
Old May 6, 2004 | 04:53 PM
Jeffvette's Avatar
Jeffvette
From: No more yankee my wankee, the Donger is tired!
Default Re: J55 Brake upgrade (mik)
They bolt directly up
Old May 6, 2004 | 05:12 PM
Gary04Z06's Avatar
Gary04Z06
Default Re: J55 Brake upgrade (Jeffvette)
:iagree:
Here is some more info: http://www.superchevyperformance.com...s/gsbrakes.asp
Old May 6, 2004 | 06:59 PM
BAM92's Avatar
BAM92
Default Re: J55 Brake upgrade (Gary96LT4)
:iagree: Also good time to upgrade to ss lines while your at it. :thumbs:
Old May 6, 2004 | 07:03 PM
rsafier's Avatar
rsafier
you can get really good prices on HD (13") rotors on RockAuto.com, just had to buy a set for mine a couple weeks ago. $67 bucks each for slotted/cross-drilled Raybestos BruteStops. Look really good with the GS caliper behind the wheel.
To J55 Brake upgrade
