anybody else running vortec heads here?
Old May 7, 2004 | 09:33 PM
atotalnincompoop's Avatar
atotalnincompoop
Default anybody else running vortec heads here?
i can't be the only one. :confused:
if you are are you using stock length pushrods?
thanks :cheers:
Old May 7, 2004 | 09:36 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Default Re: anybody else running vortec heads here? (atotalnincompoop)
What'd you pull your heads off of? I'm trying to get a set from my brother, that came off his '98 chevy pickup, but he's resisting.
How do they flow compared to the iron heads, or did you have em worked over?
Old May 7, 2004 | 09:48 PM
LT-4 CE's Avatar
LT-4 CE
From: Everyday you must choose between the pain of discipline and the pain of regret. Fredericktown, OH
thanks :cheers:
I've not used them in past projects, but going from GM cast heads to World Products heads required me to go to a slightly longer push rod with the cam I was running.
Are you giving us a glimpse into your potential problem?
Old May 7, 2004 | 10:49 PM
ZD1's Avatar
ZD1
I'm running a fastburn head which are the "aluminim" version.
Old May 7, 2004 | 11:24 PM
atotalnincompoop
Default Re: anybody else running vortec heads here? (CentralCoaster)
mine came off a '98 truck, they are pocket ported and polished up a bit, they flow great stock. the porting helps a lot too.
gm's fastburn heads are the aluminum version.
PORT SIZE: 170
CHAMBER: 64cc
VALVE SIZE: 1.94 / 1.5
FLOW@.100: 70 / 48
FLOW@.200: 139 / 101
FLOW@.300: 190 / 129
FLOW@.400: 227 / 140
FLOW@.500: 239 / 147
FLOW@.600: 229 / 151
Old May 8, 2004 | 04:37 AM
CentralCoaster
Awesome, thanks :thumbs:
Old May 9, 2004 | 08:36 AM
opel's Avatar
opel
I'm running them on my 85 I did before and after dyno runs with the only changes being heads and the vortec intake I was not happy with the HP gains all the magazines were saying 30+HP gains I only saw about 12 HP. But the torque went up close to 50 Ft-lbs that made a big diffrence in the car. I used the stock size push rods.
Dave
To anybody else running vortec heads here?
