Saw that these are worth an extra 1mph or 10hp....my question is.....
Whats the downfall to these? Do they detonate or foul any quicker? Cause any harm to engine?
Just curious why nobody (manufacturer) has come up with the.....cut back electrode plug to try to make money off of.....seeing there's just about every other type of plug out there lol
Also if Iam seeing this done correctly then there is basically NO GAP? on these...I mean the electrode if cut back totally exposes the tip....this right? I checked out 65Z01 site and saw the illustration.
The con to this mod is that the plugs in my Vette seem to need regapping about twice a year, at least that's how often I tough them up. I think this is the major reason that auto & parts mfgs don't offer a plug like this; neither the general public nor the Fed would like such a plug.
However, the IROC doesn't seem to need it but I no longer flog it down the 1/4mile regularly like I do the Vette. So the maintenance interval may well depend on how you use the engine.
I generally agree with JAKE in the above post on the benefits; for me the added HP is well worth the increased manitenance.
not quite sure about the regapping thing.....does the spark now go diagonally to the ground electrode seeing that its not directly over the tip any longer and how do you regap if the tip doesn't line up any longer?
Does this hurt the engine at all...?.....I have read everything....and what I could see is basically it provides a better burn so if anything would be better for the engine? YES?....thanks guys....
On my plugs I cut them back "almost" to the edge. The spark then will jump nealry straight up/down between the electrodes, with no shrouding from the ground electrode.
Indeed this provides a better (more complete) burn, which gives a little more power and cleaner exhaust.
Be sure to trim off any burs or sharp edges after cutting the plugs as these tend to promote pre-ignition (spark will jump from a point at lower voltage than from a smooth surface). This isn't too critical, just hit the cut edges with a fine file.
The center electode gradually wears away on the side nearest the cut back ground electrode, so yes then the spark tends to jump a little diagonally. It's best to use a wire gapping tool and just bend the ground electrode down a little to reestalish the chosen gap, stock for stock HEI and wider for hotter ignition.
ok...well iam definitely now very interested in this little mod.....every little bit helps....i don't mind the extra maintenance....I can do plugs on my L-98 now in like 45 mins....(I have gotten pretty good at it....lol)...sorry to all those LT1 guys! :crazy: :jester
My question is....I just put in AC Delco Rapid Fires last week.....so should I keep those....seeing they are platinums....and buy a cheap set to cut back? or would it be better to use the platinums to cut back?....I know that platinums last longer so we are sorta defeating the purpose of them in this application (also why Iam questioning, cause 65Z01 said he took out his rapid fires and replaced them with Split Fires that he cut back)
Be careful on these. I have a brand new set I bought last year for my '85 and after installation, my whole car went haywire. lcd flashing on and off, car stalling barely running, etc. Swapped them back out. Everything back to normal. They look just like the cut-back plain plugs I made so I'm not sure why they cause such problems, but I rather spend the extra hour doing all the plugs myself now and save the money.. hehhehe
NGK's V-Power plugs also go by the same principle. From what I've read before, the spark likes to jump to a sharp edge. NGKs have a "V" groove cut in the middle of the center electrode, allowing the spark to jump to a sharp edge.
