C4 Beam Plate Feedback
Old May 8, 2004 | 03:25 PM
cprgmr's Avatar
cprgmr
Default C4 Beam Plate Feedback
Now that the car is finally done (just a new PROM burn left), I have some time to start posting again...
While I had the engine/tranny/driveline out during the top end build, I gave Bill a call and ordered the drive shaft safety loop and the C4 beam plates. I have to admit, I was a little skeptical about the beam plates, but after the postitive feedback on the forum, I thought "what the heck, I'll give 'em a try".
Simply said... These things work! Now, when I nail it, the rear end no longer wants to kick out to the right. This thing lights up the tires in a straight line! :eek:
I can't wait to see if they help at the track. :D
Old May 8, 2004 | 05:08 PM
bogus's Avatar
bogus
Default Re: C4 Beam Plate Feedback (cprgmr)
I could not believe it either.
The interesting part, a local road that I used quite a bit, when I make a left, it becomes an off camber corner and the road crown slopes quite a bit to the right... since the addition of beam plates, it won't even kick much there!
:thumbs:
Old May 8, 2004 | 09:07 PM
rodj's Avatar
rodj
Default Re: C4 Beam Plate Feedback (bogus)
Being on the otherside of the world with prohibitive shipping costs I made my own.
Totally agree with above and if you have to do any rearend / trans removal work you will appreciate the time saving getting the top nuts off and on. Your fingers will thank you.
Old May 8, 2004 | 09:10 PM
Southern Comfort's Avatar
Southern Comfort
Damn. I only thought the beam plates provided easy access for trans removal. If I had know that it would cure the fishtail.....damn.
Old May 8, 2004 | 09:46 PM
wake's Avatar
wake
Same here... I installed mine while I was changing the exhaust... I was very happy with the performance afterward...
The funny thing is I had totally forgotten about the beam plates until I did my first WOT run with the new exhaust... The first thing I thought is hey, "something's wrong it didn't kick the rear end out on the 1-2 shift..." That's when I remembered about the beam plates and thought, "hey these things really work..." :lol:
The only thing that sucked was removing the stock nuts... Trying to hold a wrench above while turning the bolts below sure is a chore...
Old May 8, 2004 | 11:14 PM
86Moon's Avatar
86Moon
One of these days, I'm gonna add the beam plates to my Sig.... as about nthe only damn thing I don't have that I should, and want. I think the rest speaks for itself. If you can run 11's or low 12's you ain't stock (or really close to it) in C4 :lol:
At the point when they came up on the GP I was either too far along in the project (it would be a PITA to pull the duals) or I was tapped :nonod: At any rate it still seemed like a lotta bank for what it is. But, Damn sure, people swear by em' :banghead:
[Modified by 86Moon, 8:18 PM 5/8/2004]
Old May 9, 2004 | 02:41 PM
Dominic Sorresso's Avatar
Dominic Sorresso
:iagree: With these things on, I don't even think about car going anywhere but straight when speed shifting.
Old May 9, 2004 | 04:11 PM
Rkreigh's Avatar
Rkreigh
Default Re: C4 Beam Plate Feedback (Dominic Sorresso)
I've put the beam plates on 4 zr1s I've owned and they are amazing.
a hard 1 - 2 shift on my 390 LSV stroker (505 rwhp) pitched the car sideways so hard I hit my head on the drivers glass and almost got knocked out!!
not anymore since the beam plates! they make the beam plate mounting much easier too and keep the bolts from digging into the beam and losing torque.
see
http://www.lt5registry.net STORE button.
bill really scored when he invented them. very high quality, and work
better than I thought!! :D
Old May 10, 2004 | 12:03 AM
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
I had my own Beam Plate made and they sure make things alot tighter.
Old May 10, 2004 | 12:14 AM
DieL's Avatar
DieL
Default Re: C4 Beam Plate Feedback (mackeyred96)
they do work! simply incredible. I was having fun painting my friends street with super long burnouts.. i did about a 1/2 mile burnout ending in 4th and blowing the tires up... but the car stays nice and straight throughout the gear changes. oh and someone called the fire department because of all the smoke... poor eagle gscs :lolg: :rofl:
To C4 Beam Plate Feedback
