Dented runner....where to get it fixed
Old May 8, 2004 | 06:51 PM
cbrock's Avatar
cbrock
Default Dented runner....where to get it fixed
I've got some Long tubes and there are a few dents along the way. Where do you guys go to get something like that repaired?
Old May 8, 2004 | 07:37 PM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Default Re: Dented runner....where to get it fixed (cbrock)
:D I'd be curious also! Dents that you can touch from either end may be easier than dents you can't reach!
Let's see what the collective experience of the Forum has to say!
:seeya
:steering:
[Modified by jackdaroofer, 7:38 PM 5/8/2004]
Old May 8, 2004 | 08:04 PM
Bruce's Avatar
Bruce
Default Re: Dented runner....where to get it fixed (jackdaroofer)
if it small than leave it at that. I don't how are you going to fix the dent where you can reach.
If it is very bad dent, your choice is to find one in the swap meet or e bay.
Bruce
Old May 8, 2004 | 09:57 PM
Aaron's 87's Avatar
Aaron's 87
If you can reach it, the box end of a wrench and gentle persuassion can rub it out. If you can't reach it, you have to find the right size ball bearing and push it through.
Old May 8, 2004 | 11:00 PM
cbrock's Avatar
cbrock
Default Re: Dented runner....where to get it fixed (Aaron's 87)
Well this is actually on my prostreet chevelle that I just picked up. It's got 2 1/8" primaries and they're all equal length (of course one has a slip joint and wraps over the frame...ugh). Instead of getting a mini starter he just banged the pipe in...so yeah it's a pretty serious dent :D But to replace would be 600-1000.00
I'm now thinking I'll just have to have a shop cut it out and weld in a new section. Def want to take of that before I throw down the $300 for Jethot.
To Dented runner....where to get it fixed
