engine and trans. working good. installed spec single mass aluminum
flywheel for performance but now have rattling noise when in neutral
with foot off clutch petal and accelerating between 2 and 3k rpm in
most gears.Not feeling any vibration and noise goes away when clutch is
depressed. My car is 94 lt1 coupe with 6 speed. Is there a fix?
The fix is, put a dual mass flywheel in. Most who convert to the single mass know that it will be noisier.
