hub/bearing assembly question
Old May 10, 2004 | 10:07 PM
LnKLT4's Avatar
LnKLT4
Default hub/bearing assembly question
My wife Laurie and I (Kevin) got our first Corvette three weeks ago. It's a 96, Polo Green LT4 with 17500 miles on it. I took it to get Maryland inspected today and was told that the left front hub/bearing assembly needs replaced. They also said the rear need to be tightened. Is this a common issue on Vette's?
Also, the left rear and front right marker lights are out. How tough is it to change the bulb myself, if indeed it just the bulb.
One more thing. Once the radio has been on for a bit it pops and makes a loud pitched noise for a couple seconds. Any ideas? My father-in-law things an amp may be going. Any additional thoughts?
Thanks in advance!!!!
Kevin and Laurie
Old May 11, 2004 | 03:05 AM
skeet's Avatar
skeet
Default Re: hub/bearing assembly question (LnKLT4)
No these are not common issues with the C4 Corvettes. The hubs/bearings are usually good for 100,000 miles unless you are running 335x35x17 tires and using the car hard. It could be a defective front bearing or a sign of a front end accident (even a minor one like sliding it into a curb). Are all 4 tires the original ones?
I do not know what they want you to tighten on the rear end? The hubs are not adjustable. Were they more specific about what needed to be tightened?
Can you go to another inspection station or are you in their computer?
The bulbs are easy to do-if I remember correctly it is just a matter of loosening the screws to the plastic lens and replacing the bulbs.
No idea about the radio- is it the Bose? then maybe the amps.
How much did you pay for the car. I bought my 95 with the exact same mileage last year for $17,500.
Good luck with the car - it seems like a beauty.
Old May 11, 2004 | 09:02 AM
scorp508's Avatar
scorp508
Default Re: hub/bearing assembly question (skeet)
I have to disagree and say that hub replacement is a common issue that we all go through at some point. Bulb replacement is simple. :yesnod:
Old May 11, 2004 | 09:16 AM
chucks88's Avatar
chucks88
Default Re: hub/bearing assembly question (scorp508)
On a 17K car :skep:
Old May 11, 2004 | 09:20 AM
scorp508's Avatar
scorp508
Default Re: hub/bearing assembly question (chucks88)
On a 17K car :skep:
It only takes one really good pothole to do damage. Drive around Boston and you'll see what I mean. :D
vader86's Avatar
vader86
Just what exactly did they do to check that bearing? What did they mean when they said 'tighten' the rear one, tighten a bolt? because you cant take it apart or anything.
Wheel bearings are something we all end up replacing and theyre expensive because its a sealed unit especially for the C4.
But 2 of them should not be out on a 17K car, mileage is more important with these things.
Old May 11, 2004 | 09:23 AM
edsalinas's Avatar
edsalinas
St. Jude Contributor
The bulb holders are accessible from the top, twist and remove.
The hub/bearing assemblies do wear out, in 17,500 miles? Depends on the previous driver??? Who knows??? I'd put the car in the air alittle and check for play all around.......
Enjoy your new toy.
:cheers:
Old May 11, 2004 | 09:39 AM
LnKLT4's Avatar
LnKLT4
Thanks a lot for all of the responses. The receipt and estimate say that "wheel bearings" on both sides on the rear need tightened and one front hub/bearing assembly needs replaced. Is tightening the rear wheel bearings legit?
I'm a little slow and inexperienced but I'm sure I can get the bulbs for the markers changed, we'll see.
Should I get a GM hub/bearing assembly or get it somewhere else?????
Thanks!!
Kevin and Laurie
Old May 11, 2004 | 09:43 AM
LnKLT4's Avatar
LnKLT4
Skeet, we bought ours for 20k. It was an Ebay thing so we're either brave or stupid. It seems to be in pretty decent shape overall. It has a B&B tri-flow exhaust and an SLP (if I recall) intake. I'm a little disappointed to have to put money into it already but hey, such is life. We bought it with 17355 on it. There is also a crach in the top so I'll probably try to locate another one. The previous owner is supposedly going to help get that because he didn't know about it. I need to send some pictures of the crack to him.
Old May 11, 2004 | 09:45 AM
scorp508's Avatar
scorp508
Not really as they are a sealed unit. The only thing they "could" try with no guarantee that it'll do anything is to torque your 36mm spindle nuts to 200 ft/lbs (recommended for a stick shift car like yours, but you won't find it in the books) and see if that helps any.
Pepboys should have the rears for about $139 with a lifetime warranty. If you have an Autozone and Pepboys in the same town the fight each other for prices.
There is a "trick" to the fronts. If you buy a front one for a particular year firebird/camaro it is IDENTICAL to the Corvette one except for the mounting bolts go in the opposite way. Turn the bolts around and save yourself the Corvette tax you would have paid for the higher priced corvette one with the bolts going the right way. I forget what year it is you want to buy, so I'll let someone else remind us all.
Old May 11, 2004 | 06:35 PM
TomH91's Avatar
TomH91
Fronts: 94 Firebrid. Cheap at Pep Boys (I like SKF bearings). Scorp's right, just reverse the bolt direction. Not a hard job. Enjoy your car.
Old May 12, 2004 | 05:47 AM
DieL's Avatar
DieL
Default Re: hub/bearing assembly question (TomH91)
im tired to try to understand that :confused: what do you mean by reversing the bolt direction??
thx
Old May 12, 2004 | 10:40 AM
scorp508's Avatar
scorp508
Default Re: hub/bearing assembly question (DieL)
thx
The mounting bolts for Corvette go backwards to how the mounting bolts for Firebird go. Flip them around in the bearing and you're good to go.
Old May 12, 2004 | 10:52 AM
edsalinas's Avatar
edsalinas
Here's a pic, it shows the knuckle without the hub/bearing assy. Look close you can see where the hub assy bolts to the knuckle. The bolts are inserted thru a large hole in the hub flange that the lugs are pressed into.
Hope that helps clear it up.......
:thumbs:
Old May 12, 2004 | 03:55 PM
brookman's Avatar
brookman
Default Re: hub/bearing assembly question (edsalinas)
Here's what the bearing looks like for the front.
To hub/bearing assembly question
