Funny electrical problem
Old May 10, 2004 | 11:45 PM
sidewinder's Avatar
sidewinder
Default Funny electrical problem
1989 L98 coupe
Got in my vette for the first time in a week and after starting noticed the dash lights weren't working. Both turn signal indicators and high beam indicator stayed on continously. After a few bumps dash lights came back on and everything went back to normal. Must be a relay. Anybody know which one?
Old May 10, 2004 | 11:51 PM
ffvetteman's Avatar
ffvetteman
Default Re: Funny electrical problem (sidewinder)
That is funny
:lolg: :lolg: :lolg:
Old May 10, 2004 | 11:53 PM
ffvetteman's Avatar
ffvetteman
Just kidding
There is a way to fix it.
Do a search on this site or the internet and you will find it.
Its not a relay
Its a ground issue
Old May 11, 2004 | 12:14 AM
sidewinder's Avatar
sidewinder
Default Re: Funny electrical problem (ffvetteman)
Thanks for the tip. Gotta be a bad ground. A search discribed my problem too the tee. Should be a easy fix. :hurray:
Old May 11, 2004 | 11:00 AM
rick lambert's Avatar
rick lambert
Bad ground-easy fix.Gordon Killebrew "Inside the compartment, drivers side, find where the main wiring harness goes thru the bulkhead, attached to this is an object about the size of a dime, 1/2 inch thick with two wires connected to it (this is the ambient over ride sensor, don't worry about it) just splice a wire to the black/white wire run it through the bulkhead and ground it, there should be a ground wire attached to the frame by the battery-I cleanded and used this one. The black/white wire initially comes from cavity D3 on the cluster-this is one of the cluster ground wires. Hope this helps. :thumbs:
To Funny electrical problem
