LT1 fuel filter.
Old May 11, 2004 | 02:17 PM
scorp508's Avatar
scorp508
Default LT1 fuel filter.
Anything special? Same location and line wrenches as used in replacing one for an L98?
Old May 11, 2004 | 02:19 PM
Jim Martley2's Avatar
Jim Martley2
Default Re: LT1 fuel filter. (scorp508)
It is a ROYAL pain to change due to the location. It is just above the pre-cat on the passanger side. If it is a conv. you also have to drop the X-brace.
Old May 11, 2004 | 02:23 PM
scorp508's Avatar
scorp508
Default Re: LT1 fuel filter. (Jim Martley2)
Yeah I'm aware of that stuff, just wondering if the LT1 is any different from the others.:)
Old May 11, 2004 | 03:21 PM
VR'92's Avatar
VR'92
From: I'm the walkin dude I can see all of the world...
St. Jude Donor '03
I didn't think it was tough at all. I don't have cats though so maybe I had more room. Pretty sure its in the same spot as the L98 the passenger side kinda on the frame. Its a big ol can you can't miss it!
Old May 11, 2004 | 04:55 PM
JasonL's Avatar
JasonL
Default Re: LT1 fuel filter. (VictorRussell'92)
I think the part# is the same as L98? Location is the same, only difference is the LT1 passenger cat makes access more tricky.
Old May 11, 2004 | 04:59 PM
Nathan Plemons's Avatar
Nathan Plemons
Default Re: LT1 fuel filter. (JasonL)
It's not HARD to change. You just won't be able to do it without taking a gasoline bath.
Old May 11, 2004 | 06:30 PM
Steel Blue 91's Avatar
Steel Blue 91
Just ran a check at auto zone...the part numbers are the same for both my 91 (L98) and a friends 93 (LT1). I assume the the tools, etc. required will be the same.
Old May 12, 2004 | 12:31 AM
BAM92's Avatar
BAM92
Default Re: LT1 fuel filter. (Steel Blue 91)
Yep like Nathan said your gonna spill alot before it is over.
Old May 12, 2004 | 12:39 AM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Yeah, it's better if the stock cats are gone. Headers actually make it much easier to change. But it's not too bad anyway. Just get the car high enough so you've got some elbow room. And I'm sure you know how to keep from getting a gas bath! I just picked up a Napa Gold today so I'm getting ready to do it again too.
[Modified by Corvette Kid NC, 12:42 AM 5/12/2004]
Old May 12, 2004 | 01:14 AM
JasonL's Avatar
JasonL
Default Re: LT1 fuel filter. (Corvette Kid NC)
Maybe I'm just lucky? I wore rubber gloves and caught all the fuel in a catch pan, didn't get any on my skin at all. I made sure not to put my head underneath as I disconnected the fittings.
To LT1 fuel filter.
