AIRCONDITIONING SYSTEM PROBLEM
Old May 11, 2004 | 11:08 PM
VETTEMANIAC's Avatar
VETTEMANIAC
Default AIRCONDITIONING SYSTEM PROBLEM
I CANT SEEM TO GET MY AIRCONDITIONER TO TURN ON IS THERE A WAY TO TROUBLE SHOOT THE SYSTEM? I CHECKED THE FUSE AND THERE IS POWER TO BOTH SIDES BUT WHEN I CHECK THE PLUG ON THE PUMP THERE IS NO POWER. MY CHILTONS GIVES ME NO INFO ON THIS CAN SOMEONE HELP ME?? :confused:
[Modified by VETTEMANIAC, 4:09 AM 5/12/2004]
Old May 11, 2004 | 11:15 PM
usavetteboy's Avatar
usavetteboy
Default Re: AIRCONDITIONING SYSTEM PROBLEM (VETTEMANIAC)
U PROB HAVE CHECKED THIS BUT IT WILL NOT COME ON WITH A LOW FREON CONDITION
Old May 11, 2004 | 11:22 PM
VETTEMANIAC
Default Re: AIRCONDITIONING SYSTEM PROBLEM (usavetteboy)
IF IT IS A LOW FREON PROBLEM WILL THE COMPRESSOR EXCEPT A CHARGE IF IT WONT ENGAGE THE CLUTCH??
Old May 11, 2004 | 11:25 PM
JB666's Avatar
JB666
THAT SHOULD NOT EFFECT IT'S ABILITY TO TAKE A CHARGE YOU SHOULD GET IT DONE BEFORE THE SUMMER RUSH
Old May 11, 2004 | 11:30 PM
MtlSphere's Avatar
MtlSphere
SunCR is the MAN when it comes to Vette A/C issues!
For my $.02...you can unplug the low pressure switch from the larger line near the firewall and jumper it with a paper clip to get the compressor to run while you add R12/134a.
I suggest taking the hit and buy yourself a good set of manifold guages. I have found them to be indespensible when working on my Vette's A/C. As a matter of fact I checked my A/C this afternoon and only had to add about a pound to bring her up to speed for this summer. I'm thinking a Targa shade and darker tint wouldn't be a bad idea either. :seeya
Old May 12, 2004 | 12:22 AM
VETTEMANIAC
Default Re: AIRCONDITIONING SYSTEM PROBLEM (MtlSphere)
SO IF I HAVE A LOW FREON CONDITION WHEN I ACTIVATE THE AIR SWITCH THE COMPRESSOR CLUTCH WILL NOT ENGAGE AND THE COOLING FAN WILL NOT COME ON EITHER ? THIS PROBLEM SEEMS TO APPEARED AFTER I TOOK HER OUT OF STORAGE ITS A 1985 IF THAT MAKES ANY DIFF. ALSO WILL I BE ABLE TO RECHARGE THE SYSTEM WITH A 134 KIT?DO I HAVE TO RESET ANYTHING ON IT AFTERWORDS??
[Modified by VETTEMANIAC, 5:24 AM 5/12/2004]
Old May 12, 2004 | 12:42 AM
SunCr's Avatar
SunCr
As suggested, disconnect the low pressure switch and jumper the harness with a paper clip. If it runs, the charge is probably low.
I'm not a fan of dumping in R134 via one of the quickie conversion kits. You need to get all of the R12 out first. Mixing the 2 refrigerents will increase operating pressures, sometimes high enough to trip the high pressure switch (and if it doesn't, it's just going to blow up). So, if you want to use R134, get all the old stuff out first, swap out the accumulator and orifice, pull a vacuum, and then recharge using ester (not pag oil) for the lubricant.
Old May 12, 2004 | 11:45 PM
VETTEMANIAC
Default Re: AIRCONDITIONING SYSTEM PROBLEM (SunCr)
Thanks for the info guys it is working great the only problem I have now is that I cant get the fans in front of the radiator to work when I turn on the AC and the one behind the radiator cycles on and off. I disconected the battery to reset the pcm and it still doesnt work. Is there a sensor that im not aware of??
Old May 13, 2004 | 12:55 PM
SunCr's Avatar
SunCr
Aux fan in front of the radiator is independent of a/c operation. On your year, I believe the switch for it is in the right head between the 6 & 8 plug. It will close and ground the relay when coolant temps reach 228 degrees. Grounding the wire should turn on the fan.
Old May 13, 2004 | 02:07 PM
dwestsr's Avatar
dwestsr
:iagree: :iagree: :iagree: :iagree:
SunCR is right on target. If you convert to R134A , do it the right way or you will be replacing more than the freon. :cheers:
Old May 16, 2004 | 07:04 PM
VETTEMANIAC
THE AC WORKS GREAT NOW THE ONLY QUESTION I HAVE IS THE COOLING FAN CYCLES ON AND OFF NOW IS IT NOS SUPPOSSED TO RUN ALL THE TIME THE AC IS ON? AND IF SO HOW DO I CORRECT THIS ? T.I.A.
Old May 16, 2004 | 07:58 PM
SunCr's Avatar
SunCr
It's suppose to cycle on and off. Most of the early C4's use a dedicated switch on the high pressure (smaller line from the condensor to the evaporator) that will open at about 233 psi signalling the ECM to ground the main fan relay. The cooler air flow across the condensor drops the pressure and when it it gets to about 170 psi, the switch closes and ECM shuts the fan off. The idea is to keep the low side at 22 to 28 psi which gives the best vent temps. Later C4's incorporate the signal into a pressure switch which the ECM uses to control both fans, fan speed and to monitor the status of the a/c system all of which can be read by a scanner. The idea is the same though - keep the operating pressures within the ideal operating range.
[Modified by SunCr, 4:59 PM 5/16/2004]
To AIRCONDITIONING SYSTEM PROBLEM
