wont start !!!
Old May 12, 2004 | 01:35 PM
devil427's Avatar
devil427
Default wont start !!!
HI !
my 88 vtte will not start ,after 6 month storage , i check : fuel :ok, ignition:ok, change fuel pump ,and almost everythingh ........NO START , one thing strange : the spark plugs are dry , and i had some pops in the manifold ,and even fire one time ....!! it look like if there was not enough advance ,or injectors ??? PLEASE HELP !! THANKS :mad
Old May 12, 2004 | 02:19 PM
Cherry6speed's Avatar
Cherry6speed
Default Re: wont start !!! (devil427)
Sounds to me like you missed something. If you have fuel and fire then it should run. Re-check the fuel. Do you have fuel comming out of the line? Can you hear the pump running? Did you check the fuel pump relay? Re-check everything dry plugs=no fuel. Good luck :cheers:
Old May 12, 2004 | 03:11 PM
86Moon's Avatar
86Moon
I know this seems stupid, but I didn't see the fuel filter mentioned :confused: Then you could throw a guage on the fuel rail and check the pressure to the rail. I hate to mention it, but defective new parts can happen.
To wont start !!!
