BRAKES ??????????
Old May 12, 2004 | 06:06 PM
needac5's Avatar
needac5
4th Gear
Default BRAKES ??????????
My brakes(91) lost all pedal the other day I mean all not spongy but just straight to he floor. I wasn't sure what happened but i had unhooked the brake booster line at the plenum a few weeks ago when i replaced the intake gaskets. So to rule out air just in case i bled the brakes today and the back ones looked fine but the fronts.... nothing , i mean nothing ever came out. does that idicate a bad master cylinder and not a bad booster or not necessarily??? also how hard is it to rebuild a master cylinder or should i just get a new one? thanks for the help!!!!
Old May 12, 2004 | 06:07 PM
vader86's Avatar
vader86
Default Re: BRAKES ?????????? (needac5)
Master Cylinder, get a new one.
If thats the problem, this JUST now started? Usually it should have been noticable earlier if it was the MC.
[Modified by vader86, 5:08 PM 5/12/2004]
Old May 12, 2004 | 06:23 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Default Re: BRAKES ?????????? (vader86)
:iagree: Yep, a failed booster wouldn't cause you to lose your pedal, it would just greatly increase effort. And make sure it IS a new one. Don't mess around with rebuilt master cylinders.
Old May 12, 2004 | 08:50 PM
88vettelover's Avatar
88vettelover
Default Re: BRAKES ?????????? (Corvette Kid NC)
Either the master cylinder is done for, you blew a brake line, or the hose ruptured. Either of these are pretty common. If you notice no fluid leaking, change the master cylinder with a new one, not a reman.
If your booster would've went bad, it would've taken you two feet on the brake pedal as hard as you can to get it to stop.
To BRAKES ??????????
