timing sets
Old May 14, 2004 | 02:23 AM
devilfish's Avatar
devilfish
Default timing sets
Im going to use the hotcam with 1.6 rockers. And heads with springs that allow around "580 in lift. Is my OEM timing set with new chain enough?
Old May 14, 2004 | 06:25 PM
devilfish's Avatar
devilfish
Default Re: timing sets (devilfish)
tt
Old May 14, 2004 | 06:57 PM
SBNova's Avatar
SBNova
Probably. But theres something I always go by- Never see your oil pump or your timing chain without replacing it. They are both too cheap, yet very labor intensive to change later.
Old May 14, 2004 | 08:11 PM
Muffin's Avatar
Muffin
Default Re: timing sets (SBNova)
SBNova is correct. Put in a new one.
Old May 16, 2004 | 09:13 AM
devilfish's Avatar
devilfish
Default Re: timing sets (Muffin)
yeah I will put in a new chaing. I just wounder If I have to go with a true roller chain?
Old May 16, 2004 | 11:02 AM
JAKE's Avatar
JAKE
My recommendation is NOT to replace JUST the chain.
Replace all threes peices, cam and crank sprockets and chain. They come as a matched set and wear together as a set.
Pretty much the same idea as flat tappet camshafts and lifter or, if you want to get **** about it, pushrods and rockers.
Jake
To timing sets
