93LT1 Temp Guage not working
Old May 14, 2004 | 12:44 PM
vetteman9368's Avatar
vetteman9368
From: I have no tolerence for liberals and fools, but sometimes i repeat myself
CI 3-5-7-8-9 Veteran
St. Jude Donor '08
Default 93LT1 Temp Guage not working
new sender in teh block, guage doesn't register, just sits on cold :confused:
Old May 14, 2004 | 12:47 PM
vetteseniorcit's Avatar
vetteseniorcit
Default Re: 93LT1 Temp Guage not working (vetteman9368)
Do you get a digital readout? If you do, the analog is toast. If neither works, there's an open circuit somewhere.
Old May 14, 2004 | 12:49 PM
vetteman9368
St. Jude Donor '08
Default Re: 93LT1 Temp Guage not working (vetteseniorcit)
didn't check the digital, but where would there be an open circuit?
Old May 14, 2004 | 12:54 PM
vetteseniorcit
Perhaps a corroded connector somewhere??? The wiring to the sensor is somewhat exposed; damaged in some way? Best place to start is the wiring at the sensor itself; the connector may be damaged, dirty or corroded. After that, it's a slow process.
Old May 14, 2004 | 02:12 PM
Darkgh0st's Avatar
Darkgh0st
I have the same problem. Digital works fine, analog doesn't. They are seperate sensors then? Its the oil temp one.
:cheers:
To 93LT1 Temp Guage not working
