[L98] Air Conditioning Removal
Old May 14, 2004 | 03:14 PM
FlyboyZR1's Avatar
FlyboyZR1
Default [L98] Air Conditioning Removal
Since I have to put it a new radiatior, I figure this will be a good time to rip out the A/C. It doesn't work well, I never use it, plus it robs power when it's being used.
Is there anything I need to be aware of, or can I just start ripping it out?
Is there an eliminator bracket of some sort available?
I'll probably just start with removing the condenser, and work backwards from there.
Old May 14, 2004 | 04:35 PM
NavyVet's Avatar
NavyVet
Default Re: [L98] Air Conditioning Removal (FlyboyZR1)
I suggest "bleeding off the pressure" from one of the schraedeer valves first with a hose to a bottle to collect the oily residue. Once all pressure is relieved, remove at will. Some sue a shorter belt. I use a Guy Ankeny Racing "A/C eliminator bracket with pulley" and retian the roiginal belt angularity on the tensioner and under the water pump. Good luck, Paul :flag
Old May 14, 2004 | 09:29 PM
FlyboyZR1's Avatar
FlyboyZR1
Default Re: [L98] Air Conditioning Removal (NavyVet)
How much was the eliminator bracket/pulley? I've also heard a Chevy S10 A/C eliminator bracket bolts right in.
Also am I going to lose any defroster fuction after removing the A/C?
To [L98] Air Conditioning Removal
