87 Coupe, front marker lite question
Old May 16, 2004 | 02:19 AM
lallend's Avatar
lallend
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13
Default 87 Coupe, front marker lite question
When I turn on the lights, should the front side yellow lights glow the same as the rear side red ones? Or should it only light up when the turn signal is flashing? Or both, when lites are on, yellow front side lites on with the head lights and flash on and off with the turn signal?
Old May 16, 2004 | 01:26 PM
c4cruiser's Avatar
c4cruiser
Default Re: 87 Coupe, front marker lite question (lallend)
With the headlamps (or parking lights) on, the yellow side marker lights should be on. When you turn on a turn signal with the lights on, the yellow side marker lamp will flash alternately from the front turn signal bulb. With the lights off, the yellow side marker will flash at the same time as the front turn signal bulb.
This is pretty much a GM standard in how the front side markers and front turn signal bulbs operate with the lights on or off.
Old May 16, 2004 | 02:14 PM
lallend's Avatar
lallend
Default Re: 87 Coupe, front marker lite question (c4cruiser)
Thanks c4cruiser, guess I have some wiring issues to sort out!
To 87 Coupe, front marker lite question
