Help with Caliper change/repair
To do so, you have to get them off the car, repair replace and reinstall...not sure from your post if you are comfortable with that!
Dust boots are fairly easy!
E mail me if you want more info
Jack
:seeya
Remove calipers
Place a piece of 2x4 where the rotors go
Use compressed air to pop pistons out until they meet the wood.
Remove aire and replace with a shop towl/rag
Apply compressed air again. (1 piston will come out)
Use a pair of rubber coated channel locks to remove other piston
Pull the dust boots
Pull the inner seals (if the dust boot is broken, guarantted there is dirt in the piston cylinder)
Take a paper towel or shop towel and wipe cylinder dry and clean
Insert new seal
Take fresh brake fluid and apply to cylinder wall
Slip new dust boot over the piston towards the base
Use a small flat blade scredriver or dental pick to place rubber dust boot into caliper
Slowly push the piston into the caliper with your fingers
Then bolt the caliper back on and bleed with new fluid.
Remove calipers
Pull the dust boots
Insert new seal
:iagree: This is the way to do it. Just rebuilt mine last weekend. The seal kits were ~ $7.50 each from gmpartsdirect.com.
