Diagnostic Codes 1994 LT1
Old May 16, 2004 | 11:46 AM
Debbi's 94 coupe's Avatar
Debbi's 94 coupe
8th Gear
Default Diagnostic Codes 1994 LT1
I can read HVAC system diagnostic codes from my climate control unit on my 1994 by pressing and holding both fan arrows for about 5 seconds to enter diagnostic mode. Once -00 appears I can use the arrows to select a parameter number and then press the fan button to get the "value"
I found a list of diagnostic codes awhile ago on the Idaho Corvette Page, but my unit has more parameter #s than is listed on the Idaho Page. Also, some "values" I get are different from what is shown on the Idaho Page.
Does anyone know where I can find more information about how to use this diagnostic feature or a more detailed list than the one on the Idaho Page?
I'm in BC, Canada and am going to have to get hold of a shop manual. I imported the car from Arizona last fall.
Any advice or information is appreciated. Thanks : :confused:
Old May 16, 2004 | 02:27 PM
rick lambert's Avatar
rick lambert
Default Re: Diagnostic Codes 1994 LT1 (Debbi's 94 coupe)
Try this Debbi, http://www.c4vettes.com or http://www.c4vettes.com/ecm.htm hope this helps :thumbs:
Old May 16, 2004 | 03:09 PM
redcorvettedave's Avatar
redcorvettedave
Default Re: Diagnostic Codes 1994 LT1 (rick lambert)
:confused: how can i get my code without a scan tool for my 94???????????????
Old May 16, 2004 | 11:39 PM
Debbi's 94 coupe
8th Gear
Default Re: Diagnostic Codes 1994 LT1 (redcorvettedave)
Thanks Rick, I read the information on the links.
Dave, we need a scan tool to read the codes from our 94 OBD-I units as some changes were introduced in 94. The link Rick sent has more details.
:seeya
Old May 17, 2004 | 12:59 AM
redcorvettedave
QUOTE--------------------------------------------------------------------------
----------------------------------------------------------------------------------- :party: just pulled my code without the scan tool......I took a big safety pin and pliers cut off the head and it look like a "U" shape plugged one end in the number 4 pin on my pcm connector rite under dash and the over end in number 12 .....turn ignition on start ...don't start car code came up....
, http://www.c4vettes.com just click on the link.......click on the top home page then...click on the ......FACTS SHEET.......then click on TROUBLE CODE RECOVERY....and there was the instuction for pulling codes on a 94 or 95 OBD 1 ...pcm
[Modified by redcorvettedave, 6:06 AM 5/17/2004]
Old May 17, 2004 | 02:34 PM
John Row's Avatar
John Row
Here's a good link to read codes. http://www.c4vettes.com/codes.htm
To Diagnostic Codes 1994 LT1
