Fuel injector problem ? question
Old May 16, 2004 | 09:44 PM
HG's Avatar
HG
Default Fuel injector problem ? question
88 stock L98. 60K miles. tarts right up when cold. Hard to start when hot. Cranks several times befor starting. No smoke when it does start. Hear a slight pop or rough idle for just a second. Could this be a leaking injector. If so, should you have only the bad one replaced or all eight :cuss
Old May 16, 2004 | 10:24 PM
NOT-MEE's Avatar
NOT-MEE
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06-'07
Default Re: Fuel injector problem ? question (HG)
doesn't sound like a leaky injector to me sound like something electronic that has a heat issue.If you do replace your injector replace them all not just one easier and you will just have to take the plenum off once
Old May 16, 2004 | 10:54 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Since it starts easily hot it doesn't sound like a bad injector.
I would put a gauge ($30 at AutoZone) on the Schraeder valve and see if pressure drops off rapidly after you turn on the ignition.
If needed, it's best to send all 9 injectors in for recoditioning; Rich at Cruzin performance (link on my site) is da man.
Old May 17, 2004 | 10:40 AM
jmrl98's Avatar
jmrl98
Get a shop manual and do the tests for injectors and FPR. Replace/recondition them all if you go for it. :seeya
Old May 17, 2004 | 08:44 PM
HG's Avatar
HG
Default Re: Fuel injector problem ? question (jmrl98)
How about a injector cleaner first :withstupid:
[Modified by HG, 8:45 PM 5/17/2004]
Old May 17, 2004 | 08:55 PM
Alzado77's Avatar
Alzado77
I would check the fuel pressure first. It doesn't sound like an injector leaking. If that was the case it would crank for about 5 or 6 seconds before it would start, cold or hot. I had a simular problem with mine and it turned out to be a bad fuel pump check valve. I fixed it with a $54 new pump from Auto Zone that was a perfect fit and took less than 2 hours to replace. My symptoms were that if it was cold it took about 5-6 seconds for it to start. If it was hot and had been running recently it would take 4 or 5 try's and it would sputter and die each time. If that is your problem it is either a leaking check valve in the fuel pump or a leaking injector probably. I took out the fuel pump and could blow air through it both ways. Shouldn't be able to do that if the check valve is working. If you do end up needing a set of injectors though, you might want to check out http://www.fiveomotorsport.com/ I bought an entire set of injectors for my 1990 for $190 and they work great. Fixed my problem and it was much cheaper than the $100 a piece the dealer wanted. They were also pretty easy to replace (about 3 hours). A 7" long T40 start wrench from Snap On to get the runner bolts out was the key. Al
To Fuel injector problem ? question
