cooling fan operation
Also in what little info is given by the haynes manuals it looks as though the TCC is also controlled by the same ground as the fan relay ( dk green white stripe) could anyone confirm this for me ( i either dont get TCC lock up, or it is continusly locked, which (while driving it with the fan jumper removed the car seemed far more aggressive in acceleration) i tend to suspect)
If you would like the engine to run cooler, install a lower temp T-stat & a matching aux fan switch and then wire it turn on the main fan. See my C4 Tech Tip on how.
The fan relay has nothing to do with the TCC. The ECM controls the fan but has no feedback from it.
You can check the TCC status by putting a test light between pins F & A on the ALDL. When the ECM issues the lockup command the light will go out, otherwise it will be lit.
BTW, the ECM cannot lockup the TCC in 1st gear due to A4 design. With a stock TC you may not be able to notice when the TCC locks up. However, even if the ECM is sending the lockup command it may not be locked, so you can try this easy test:
-while rolling along in 4th gear at about 1,000 or 1,200 rpm touch the brake pedal to unlock the TCC and then tap the accelerator. If unlocked you should see the tach jump to near 1,500rpm.
-Then repeat the test without touching the brake pedal; if the TCC is locked the tach won't jump noticibly.
