Interior lights flicker
Old May 17, 2004 | 01:48 PM
w8n4ya's Avatar
w8n4ya
4th Gear
Default Interior lights flicker
Here's my problem...
my DOOR AJAR light stays on in my dash, and my interior lights flicker on & off depending on the road conditions. I've checked my doors & rear hatch, they all are sealed shut. Sometimes when I exit my car...the interior lights never even go off. I've had to remove the "courtesy light" fuse just so my battery doesn't drain over night.
Any one else with this problem? Anyone got a suggestion or a fix? Thank you all in advance.
Old May 17, 2004 | 02:00 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: Interior lights flicker (w8n4ya)
I've had that problem a year ago and went with a quick "temp. fix" that is still in there.
I stuck a thin piece of Al onto the front of the driver's door where it meets the light switch.
It's likely that one of the switches needs to be replaced and the piece of Al is a quick test to find which switch is giving the problem. Actually a piece of thick double-sided tape with the cover left on one side would work for a test only.
