Battery for PKE transmitter?
Old May 19, 2004 | 09:07 AM
KP Texan's Avatar
KP Texan
Default Battery for PKE transmitter?
I have been searching the archives and discovered that not all CR2450 batteries will fit in the PKE transmitter. Do any of you guys know which common brands will fit, if any? Some members say that Duracell will not fit but Sanyo and Toshiba will fit. All I could find at the store yesterday was Energizer but I didn't buy it because I was not sure if it would be a correct match for the transmitter. I'm sure this would be much easier if my transmitter came with a battery in it to compare but, unfortunately, it didn't. The battery should also be Lithium and not Alkaline, correct?
Thanks for the help,
Wes
Old May 19, 2004 | 09:23 AM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
Default Re: Battery for PKE transmitter? (KP Texan)
Wow, I didn't know batteries were so complicated. It is my understanding that all batteries with the same number are identical (size and type), no matter who makes them....that's the reason for having universal part numbers.
Having said that, I guess I'd better check my own PKEs when I get home; I bought a spare battery (Eveready) some months ago, now you've got me concerned about it fitting!
Larry
:seeya
Old May 19, 2004 | 09:37 AM
sraft's Avatar
sraft
Default Re: Battery for PKE transmitter? (code5coupe)
The batteries are all the same diameter but some brands are a little thicker. If you use a thicker brand it places more stress on the already weak plastic clasp that keps the two halves shut. Sooner or later (or if you give it a sudden shock like dropping it) the clasp will snap off.
Old May 19, 2004 | 01:09 PM
Tom Meehan's Avatar
Tom Meehan
If the catch snaps, like both of mine did, throw two wraps of black plastic electrical tape around it. Once it's on there you'll never know it's there. Just a thought.
Old May 19, 2004 | 02:50 PM
KP Texan's Avatar
KP Texan
Default Re: Battery for PKE transmitter? (Tom Meehan)
If I cannot find a Sanyo or Toshiba, would it be worth it to order one off the internet then? I would really like to avoid breaking my transmitter if possible. Any other brands that you guys have had success with?
Wes
Old May 19, 2004 | 04:33 PM
KP Texan's Avatar
KP Texan
Well, I just ordered 2 Toshiba CR2450s from http://www.microbattery.com so hopefully those will work alright. I'll let you guys know how they fit.
-Wes
Old May 19, 2004 | 10:40 PM
sraft's Avatar
sraft
Mine snapped also. Once you have the thinner battery, a dab of glue from a hot glue gun works great for holding the case shut.
Old May 20, 2004 | 03:14 AM
vetteseniorcit's Avatar
vetteseniorcit
The orginal battery provided with the PKE transmitter is the (Hitachi) MAXELL CR2450 (one of which I hold in my hand). It has a recessed lip to fit into the remote properly. Finding the little buggers is the problem. I guess I'll have to spend a good bit of time surfing to see if I can find a source. It is a pretty hefty battery, fairly thick.
Old May 20, 2004 | 03:29 AM
vetteseniorcit
Boy, that was an interesting search! Took all of about 30 seconds! check out the following site: http://www.combatt.com_maxell_cr2032...attery_5_.html
Scroll down to the CR2450, click the picture to enlarge the package and you will see that a lip appears to be around the edge of the battery. Tell you what I'm gonna do. I'll order 10 of these (2 packs). If they are the proper battery, I'll find this thread and mail anyone that wants one for a measly $1. I'm losing money on the deal, but out of the kindness of my heart, I'm gonna find these little orphans a home! :D
Old May 20, 2004 | 06:37 PM
John Row's Avatar
John Row
I found the correct batteries at the jewelry store while I was having batteries put in a couple of watches. They had several brands. I don't remember which one fit.
Old May 20, 2004 | 06:44 PM
Zix's Avatar
Zix
I have a Duracell in mine, but didn't have an issue putting it in. I bought it from a Walgreens in the area.
Old May 20, 2004 | 07:26 PM
IGOFASTERINMYVETTE's Avatar
IGOFASTERINMYVETTE
Default Re: Battery for PKE transmitter? (sraft)
"The batteries are all the same diameter but some brands are a little thicker. If you use a thicker brand it places more stress on the already weak plastic clasp that keps the two halves shut. Sooner or later (or if you give it a sudden shock like dropping it) the clasp will snap off. "
yep, happened to me yesterday, i have a duracel in the thing now. But, I have another remote and have yet to change the battery, so I will get one of the other brands for that one! :banghead:
[Modified by IGOFASTERINMYVETTE, 12:28 AM 5/21/2004]
To Battery for PKE transmitter?
