Dashboard Ventilation
Old May 19, 2004 | 01:00 PM
Holeshot2418's Avatar
Holeshot2418
Cruising
Default Dashboard Ventilation
The ventilation vents on the front of the dashboard no longer blow air, but the air is coming out of the vents under the dashboard (floor) and the defrost vent on the dashboard. I also noticed that my cruise control is no longer working, not sure if they went out at the same time....Any ideas?
FleX :mad
Old May 19, 2004 | 01:58 PM
Red Dwarf's Avatar
Red Dwarf
Default Re: Dashboard Ventilation (Holeshot2418)
That's the default position when you have a vacuum leak. Timwe to start checking all connections. If you have an LT1, look under the pass/side fuel rail cover. Vacuum fitting in there has been known to deteriorate?
Old May 19, 2004 | 07:12 PM
TomHamill's Avatar
TomHamill
St. Jude Donor '05
Default Re: Dashboard Ventilation (Red Dwarf)
:iagree: Also you'll probably find that the cruise control doesn't work. About a $5.00 / 5 minute fix. Vacuum fitting looks like a "Tee".
To Dashboard Ventilation
