Blinker Problem...
Old May 19, 2004 | 06:00 PM
88vettelover's Avatar
88vettelover
Default Blinker Problem...
Ok, went to drive home from work today and noticed my blinkers weren't blinking. The light in the cluster just stayed lit.
So, I turned them on and checked all the lights. All lights are functioning properly, the blinkers just aren't blinking....
OK, so my questions is: What's causing this? The blinker module? Where is it? and How much to fix?
Car: 1988 Coupe
Thanks!! :cheers:
EDIT:
Before anyone else does this....The blinker fluid is good, checked that first!! :yesnod:
EDIT (part 2):
When I turn on the blinkers, no sound, like the normal blinker sound. Just lights up and no sound.
[Modified by 88vettelover, 5:04 PM 5/19/2004]
[Modified by 88vettelover, 5:09 PM 5/19/2004]
Old May 19, 2004 | 06:04 PM
Wheelman's Avatar
Wheelman
Default Re: Blinker Problem... (88vettelover)
Sounds like you need to change your blinker fluid.... :jester
88vettelover
Default Re: Blinker Problem... (Wheelman)
AHHH!!! Just as I was editing it. I knew someone was going to bring that! :boxing
Old May 19, 2004 | 06:05 PM
Torquem's Avatar
Torquem
One element in one of your dual element bulbs is nuked. You're gunna have to track down which bulb it is and replace it.
Old May 19, 2004 | 06:08 PM
88vettelover
Default Re: Blinker Problem... (Torquem)
Checked all the bulbs already and replaced the front two and the side two. Any other ideas?
Wheelman's Avatar
Wheelman
seriously, the relay is under the passenger side dash pad, a silver round looking relay I believe :cheers:
Old May 19, 2004 | 06:10 PM
88vettelover
By dashpad do you mean the breadbox?
Old May 19, 2004 | 06:17 PM
Torquem's Avatar
Torquem
yeah it could be that too... although mine always got slower and slower till they quit when it went out... but good idea to check it
88vettelover
Mine just went out. Worked fine, got in the car and stopped working. Interesting...
Old May 19, 2004 | 06:20 PM
Torquem's Avatar
Torquem
thought provoking indeed :shocked:
im not too far away from you
Old May 19, 2004 | 06:27 PM
88vettelover
Sure aren't, I'm acutally about 20 minutes from St. Louis on the other side of the river. ;)
Old May 19, 2004 | 06:28 PM
MY84REDC4's Avatar
MY84REDC4
mine was like that when I bought the car the other guy said he would click it on and off. I changed the outside rear drivers side bulb and it worked fine after that. (had to have my girl friend reach up there because my arms wouldnt fit.)
Old May 19, 2004 | 06:36 PM
88vettelover
Default Re: Blinker Problem... (MY84REDC4)
I just went out and checked my lights again, right rear bulb is out, not the tailight but the side light. I'll have to see if that lights up when I turn the blinker on. Hmm, interesting situation we have here.
Looks like a trip to Advance. I'll keep ya posted.
EDIT:
Just checked them, they're not supposed to blink, but the bulb is burned out.
What is the name of the relay that controls the blinkers? I'm gonna make a trip to the parts store so I might as well pick that up while I'm there.
[Modified by 88vettelover, 5:41 PM 5/19/2004]
Old May 19, 2004 | 07:08 PM
Cherry6speed's Avatar
Cherry6speed
It's called a flasher....It is silver in color and all the parts houses carry it. I think Wally World has a few of them too. BLINK BLINK :yawn:
Old May 19, 2004 | 07:28 PM
Wheelman's Avatar
Wheelman
It would be behind the breadbox. The dashpad is the thing that covers the dash from the top
Old May 20, 2004 | 08:11 AM
Duf's Avatar
Duf
I have a similar issue but a bit different. If the headlights are off all blinkers work fine. If I turn on the parking lights the passenger side front signal doesn't work. I know it is one faulty bulb that is causing it, I just can't find it yet.
Old May 20, 2004 | 08:18 AM
vetteseniorcit's Avatar
vetteseniorcit
Default Re: Blinker Problem... (Duf)
A burnt out bulb will "deactivate" your turn signals. Best to replace that bulb before tearing into the rest of it.
Old May 20, 2004 | 08:57 AM
Duf's Avatar
Duf
Default Re: Blinker Problem... (vetteseniorcit)
Yea I did replace it. Actually I replaced almost all of the front bulbs. I DO have a burned out foglight but I don't think that would affect the turn signals.
To Blinker Problem...
