"Change Oil" - How Do I Turn It Off
Old May 21, 2004 | 04:31 PM
SteveBlack90's Avatar
SteveBlack90
Default "Change Oil" - How Do I Turn It Off
The "Change Oil" warning is appearing on my dash ('90 L98). Will it go off by itself after I change the oil or do I have to do something else to reset it?
Old May 21, 2004 | 04:44 PM
VR'92's Avatar
VR'92
From: I'm the walkin dude I can see all of the world...
St. Jude Donor '03
Default Re: "Change Oil" - How Do I Turn It Off (SteveBlack90)
You have to reset it. The procedure is in your cars manual. :seeya
Im also sure someone has a typed version of it somewhere.
Old May 21, 2004 | 05:24 PM
auger58's Avatar
auger58
stet 1 turn key to on,but don't start
2 press ENG MET button on the trip monitor & release. Then within 5 seconds,press & release ENG MET button agin.
3 Within 5 seconds of step 2 press & hold the range button on the trip monitor.Change Oil light will flash.
4 Hold the Range button until the Change Oil light stops flashing & gose out.When light gose out monitor is reset.If it dosen't reset turn off ignition & start over.
this is out of my 1990 owners manual.
To "Change Oil" - How Do I Turn It Off
