Transmission Converter for modified C4
just came back from a short trip with my Vette - the end was she had to be towed to the Chevy dealer ... :cry
Had white smoke behind me on the Autobahn - and oil on my rear...
Found out that I have an oil leak somewhere near the transmission converter - now I'm not sure if it is only a gasket or a bigger problem with the converter. I'll know next week.
In case it is something wrong with the converter I'd replace it with something better than stock - what do you think? Just opend the Summit catalogue and read something about TCI or B&M converters.... have no idea what would be a good choice for my slighlty modified Vette.
Your opinion counts!
So long,
Bernd
The best TC depends on your intended use. Staying with a 12" lockup TC under 2,400rpm will allow you to get by without installing an additional tranny cooler; a more radical unit will require additional cooling.
As I already have a tranny cooler installed (due to high speeds driven on German Autobahn) the other option would be possible, too.
What do you mean by "launch harder" ?
With my 2.59 gears I'm not running for 1/4mile ....
