For those who have pulled transmissions.
Old May 23, 2004 | 11:39 AM
MrSpeedyBob's Avatar
MrSpeedyBob
Default For those who have pulled transmissions.
Is the oil pan strong enough to support the engine or will I need to find another way? If so any suggestions? Thanks in advance.
Old May 23, 2004 | 11:41 AM
Aaron71771's Avatar
Aaron71771
Default Re: For those who have pulled transmissions. (MrSpeedyBob)
When I pulled my trans, I put the jack under the oil pan to support the engine, just use a piece of wood between the two. It works fine.
Old May 23, 2004 | 11:43 AM
Aaron71771's Avatar
Aaron71771
Default Re: For those who have pulled transmissions. (Aaron71771)
Also most of the engine weight is supported by the engine mounts, the jack-under-the-oil-pan trick is so you can vary the engine angle and keep it from pushing into the firewall.
Old May 27, 2004 | 07:15 PM
MrSpeedyBob
:hurray: Got it out. :hurray:
Old May 27, 2004 | 10:07 PM
Sinister87's Avatar
Sinister87
I concur with Aaron.
Old May 29, 2004 | 09:01 AM
87NassauBlue's Avatar
87NassauBlue
I have a piece of 10" X 12" plywood that I put under the pan to rest on the jack. Never jack on the pan directly, it's just sheet metal and will collapse.
Old May 29, 2004 | 09:37 AM
Rick86's Avatar
Rick86
Default Re: For those who have pulled transmissions. (87NassauBlue)
I used a transmission jack without any shoring. No problem.
To For those who have pulled transmissions.
