I just changed the fluid and filter on my 86 C4 automatic transmission. Now, when I start driving the auto shifting is delayed until about 3200 RPM and then upshifts like a kick in the butt. After driving for ten or fifteen minutes the shifting becomes more normal and smooth. I've never had any drive problems before. The fluid level is correct.
Could I have caused this in installing the filter and its seal?
If the sealring on the filter neck wasn't properly seated what would be the consequence?
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Re: Automatic gear shifting (Angusd)
A poor seal at the filter neck would cause it to suck air but whether or not that could cause your problem, I don't know. You could have a sticky valve. If it continues get a pint of Berryman's Chemtool B-12, follow the procedure for A/Ts and then repeat your fluid change.
I've seen some posts on this in the past. There was a lot of people who said that if you don't know the maintnace history of the tranny, and it has not been serviced at regular intervals that putting in new fluid can take the tranny out :eek:
I hope that will not be the case for ya and that it's something simple. But the fact that it returns to normal shifting when it gets warm is kinda :skep:
Thanks for the input. When I changed filters I extracted the old seal with a pick, but the new seal is one of those orange colored three lip rings and is quite stiff. I pushed and wiggled the filter to get the seal to seat, and I got the filter in far enough for the pan to seat...but I'm not totally sure that the sealring is properly installed.
I'm tempted to pull everything off again to recheck. that is why I wanted to know what kind of reaction a poor seal would have on performance.
The reason that I changed the filter and fluid was that I had a leak at the gasket that tightening bolts did not help. I removed the pan, straightened the pan flange where it was belled at several front bolt holes and reinstalled it with a new filter and gasket....In addition to the changeup problem, the darned thing still leaks.
