From: Sarcasm. Just one of the many services I offer.
Service engine soon!
The Service engine soon light came on today. How do I find out what the problem is? The car is fairly well maintained. In the last 2 months I have:
Replaced air filter
Replaced Spark plugs
Replaced fuel filter
Replaced and bled front and back breaks
Flushed radiator
flushed transmission
replaced differntial fluid
replaced power steering fluid
The oil was changed recently and is due for another change in a week or so.
St. Jude Donor '04-'05-'06-'07-'08-'09-'10-11-'12-'13
Re: Service engine soon! (ir0nmaiden420)
WHATS UP HEY CHECK THIS OUT ARE YOUR FANS WORKING PROPERLY. WHEN MY VETTE GOT UP TO 230 THE MAIN FANS WOULD KICK ON AND THE SERVICE ENGINE LIGHT CAME ON I KNOW THAT THIS IS PROBABLY NOT YOUR PROBLEM BUT I FIXED MINE BY CHANGING OUT THE MAP SENSOR IN THE TOP OF THE MOTOR. HOPE THAT HELPS :cool:
Re: Service engine soon! (95VETTEINMEMPHIS)
Ill check...at what temperature should the fans come on?
