'92 Tail Light Screw Size
Old May 23, 2004 | 10:55 PM
EaglEye92's Avatar
EaglEye92
Cruising
Default '92 Tail Light Screw Size
Hello everyone! I've been lurking on here for a while now, trying to soak up as much info as I can, but now I need some help.
Yesterday I discovered one of the tail light lenses was missing. Part of the plastic lens is stuck around the screws where it apparently broke off, and I don't have a screwdriver that will fit the screws. I'll hopefully be getting, or at least ordering, a replacement lens tomorrow, and need to remove the screws so I can fit the lens back on once I get it. So, before I go out to Autozone and start searching for the correct size screwdriver, I figured I'd ask the infinite source of all Corvette-related knowledge that is the CF.
I'd almost say the car was vandalized, because of the broken, jagged plastic left around the screws, but I would like to think no one would hurt my baby like that :(
Anyway, I've felt mighty silly driving around with a missing tail light lens for the past day and a half.
She deserves better than to be seen in public so obviously broken, but there is no other option.
Thanks guys!
[Modified by EaglEye92, 10:57 PM 5/23/2004]
Old May 23, 2004 | 11:17 PM
bogus's Avatar
bogus
Default Re: '92 Tail Light Screw Size (EaglEye92)
The screw driver you need is a Torx T15.
Sorry about the broken lens.
