AC Problem...
Old May 24, 2004 | 10:47 AM
C-4 Cross Fire's Avatar
C-4 Cross Fire
Default AC Problem...
A friend of mine has a problem. He has checked everything...this is what he says:
My blower is operational, the a/c command center is working with no blinking lights on it, I just charged the system with R-12, the compressor turns on and engages the clutch, the lines actually feel cold and start to sweat...
But no matter what setting I choose my a/c only blows hot air. Could this be the result of a defective a/c programmer? What's the part number for a 1990 coupe?
Any help would be greatly appreciated.
Old May 24, 2004 | 11:43 AM
Unriced's Avatar
Unriced
Default Re: AC Problem... (C-4 Cross Fire)
Sounds like he/she has a door issue in there that is not allowing cold air to flow.
If the lines are sweating you should be getting "something"... I still say door
control is the problem...
