Old Mar 6, 2015, 05:28 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: General How-Tos
Print Wikipost
Temperature question
Old May 24, 2004 | 09:38 PM
ir0nmaiden420's Avatar
ir0nmaiden420
From: Sarcasm. Just one of the many services I offer.
Default Temperature question
At what temperature will the red warning temp light come on on an 86?
Old May 24, 2004 | 10:12 PM
skateparkdave's Avatar
skateparkdave
St. Jude Donor '05-'06
Default Re: Temperature question (ir0nmaiden420)
Not sure on a 86 but it should be around 250-260 degrees FARENHEIT:p: ..260 is a full overheat for stock 90 L98..your light may come on sooner like 245 or so.
[Modified by skateparkdave, 10:51 PM 5/24/2004]
Old May 24, 2004 | 10:57 PM
jfb's Avatar
jfb
There is no red warning temperature light! The owners manual says to shut the engine off at 260F and let it cool down.
Old May 24, 2004 | 11:06 PM
xs650's Avatar
xs650
Default Re: Temperature question (skateparkdave)
Not sure on a 86 but it should be around 250-260 degrees celsius..260 is a full overheat for stock 90 L98..your light may come on sooner like 245 or so.
Since 245C is 473F, I hope your light come on well before that. :lol:
Old May 24, 2004 | 11:31 PM
skateparkdave
Default Re: Temperature question (xs650)
:lolg: UHH I MEANT 260F...I'm an idiot..yeah that'd be a hot *****!! :D
Old May 25, 2004 | 01:58 AM
JAKE's Avatar
JAKE
For the 86, three telltales are incorporated into the Driver's Information Center to serve as a warning signal if an out of normal range condition occurs on any of the following five functions: Oil Pressure, Oil Temperature, Coolant Temperature, System Voltage and Fuel Level.
There are three warning lights, one for fuel, one for oil pressure/temperature and one for coolant temp/system voltage. If the oil pressure/temp or coolant temp/system voltage goes out of range, the DIC will automatically switch to display the one that is out of range (even if it's not currently being displayed) and maximum display brightness will occur.
As far as the actual coolant temp that will trigger the warning light, I believe it's 265 F, but I'll have to look it up to be certain. Or I could just drain my radiator, fire her up and wait until the light comes on - Naw, Bad Idea.
Jake
Old May 25, 2004 | 11:25 AM
BLUE BETTY's Avatar
BLUE BETTY
on my 88 the red light comes on at 260 f,i have seen it once ,scared th heck outta me
john :shocked:
[Modified by BLUE BETTY, 10:27 AM 5/25/2004]
Old May 25, 2004 | 01:56 PM
vader86's Avatar
vader86
Default Re: Temperature question (BLUE BETTY)
Ive never seen mine come on, and Ive had it way up there on autox days.
Old May 25, 2004 | 04:07 PM
JAKE's Avatar
JAKE
Default Re: Temperature question (vader86)
I've seen my oil pressure telltale come on; new oil filter was defective.
I've seen my low fuel level light from time to time too.
I've also seen my system voltage telltale when my alternator failed a couple of years ago, but I've never had the coolant temp high enough for that one to come on.
Three out of five ain't bad though, right?
Jake
Old May 26, 2004 | 02:59 PM
Total Recall's Avatar
Total Recall
Hi,
just looked in my 86 handbook - says indicator comes on if coolant above 255 F.
:seeya
Dom
To Temperature question
