R-12 Replacement?
Old May 25, 2004 | 09:56 AM
CAJUN C4's Avatar
CAJUN C4
Default R-12 Replacement?
I know I saw it here somewhere. What is the best R-12 Freon Replacement and where can I buy some.
Old May 25, 2004 | 10:24 AM
dwestsr's Avatar
dwestsr
Default Re: R-12 Replacement? (CAJUN C4)
R134A is the replacement . I suggest you buy the kit at your local parts store so that you can replace the compressor oil with the type that is compatible with R134A (not the same oil as for R12) . You will need to rent a vacuum pump to evacuate your system and to remove and moisture and old compresser oil. It's a good idea to replace your receiver/drier at this time also. The vacuum pump will also tell you if you have any leaks.
I'm assuming that your R12 is gone, otherwise you will need to take your car to a shop that has the proper equipment to remove the R12 without venting it to the atmosphere. It is both illegal and bad for the environment to release R12 into the air.
If you simply add the 134A to your system, with out removing the old R12 it will die in a short time. :cheers:
Old May 25, 2004 | 12:09 PM
CAJUN C4's Avatar
CAJUN C4
Anyone Use ES12A?
Old May 25, 2004 | 01:01 PM
Tom Piper's Avatar
Tom Piper
Anyone Use ES12A?
I don't know what ES12A is.
But, if it is a "blend", it is best to stay away from blends -- the different size molecules in blends will tend to leak at different rates and eventually your "blend" is no longer blended correctly. Even if you add more of the "blend" the blend is not correct unless you evacuate the system completely and start from scratch. Plus, some "blends", after they become un-blended, become a fire hazard.
I would stick with R12 or R134a.
Tom Piper
Old May 25, 2004 | 09:57 PM
JackDidley's Avatar
JackDidley
Default Re: R-12 Replacement? (Tom Piper)
Im going to add something here that wont be "approved" by a lot of guys, but here goes. 4 summers ago I bought an 89 Camaro. The AC did not work.
This is my dogs car and they need AC. I gambled $35 on a 134 conversion kit and 30 minutes later it was blowing cold No vacuum. Just put it in. It still blows so cold you cant just keep it on max. This is 4 years and 20k miles. So try it if you need it. :chevy
Old May 25, 2004 | 10:18 PM
danno85's Avatar
danno85
Default Re: R-12 Replacement? (Spankyellow)
I converted my '85 to r134a but I replaced the rec/dryer, removed
the compressor and drained the oil, refilled w/recommended synthetic,
replace all o-rings with the blue ones, replace the expansion tube,
evacuated and charged w/r134 (put in 2/3rds the recommended r12 charge) and it's been working great.
Dan
Old May 26, 2004 | 12:27 PM
CAJUN C4's Avatar
CAJUN C4
TOM See
http://www.azaircare.com
Old May 26, 2004 | 12:28 PM
CAJUN C4's Avatar
CAJUN C4
Old May 26, 2004 | 03:13 PM
SunCr's Avatar
SunCr
http://www.epa.gov/ozone/snap/refrig...html#otherinfo
Illegal in the US.
Old May 26, 2004 | 05:02 PM
CAJUN C4's Avatar
CAJUN C4
http://autorefrigerants.com/
Mfg, by Envirosafe Looks Like a Great Freon Replacement.
Old May 26, 2004 | 06:49 PM
SunCr's Avatar
SunCr
What's so great about something that once you put it in your car, no shop is going to touch it? And if you buy the marketing hype and don't get the water out of the system, you're compressor will self destruct in short order, at which point you'll need to replace all most everything. 12a is a hydrocarbon blend specifically banned by 11 States including Louisiana. It's flammable, though the flash point is pretty high which means that normal exhaust heat probably won't light it off. Having a leaky evaporator (GM's are notorious leakers) and lighting up a smoke might be another story. And if you butt end somebody and have an engine fire, you might get a flame thrower with gas spewing from the condensor at 200psi. The OEM's experimented with HC's and gave up - essentially admitting they couldn't make a leak proof system. Must be me - maybe because I can get enough R12 to charge mine for less than 100 bucks - but I don't see anything "great" about this stuff.
To R-12 Replacement?
