Timing advise needed also...
Old May 25, 2004 | 05:30 PM
darkman5001's Avatar
darkman5001
Default Timing advise needed also...
Check my sig guys. I have an 86. Do you recommend any paticular setting for my timing with my current mods? Thanks!
:cheers:
Old May 25, 2004 | 07:22 PM
rick lambert's Avatar
rick lambert
Default Re: Timing advise needed also... (darkman5001)
I'd go somewhere between 8 and 10 degrees BTDC. ;) ;)
Old May 25, 2004 | 07:31 PM
CFI-EFI's Avatar
CFI-EFI
The best way to find the optimim timing for YOUR car is to run it through the 1/4 mile. Advance it 2* and do it again. You're looking for the maximum MPH. Keep advancing until the MPH fails to increase, then dial it back to the highest previous setting. Mine is at 14* BTDC.
RACE ON!!!
To Timing advise needed also...
