84 running like poop
Old May 25, 2004 | 06:07 PM
vettie85's Avatar
vettie85
Cruising
Default 84 running like poop
Hi my friends 84 is running like poop. He can't even powerbrake were before he could smoke them from off the line. And theres a big miss at low RPMs. We have ajusted the timing used fuel cleaner now what. could it be fuel filter???? THANKS
Old May 25, 2004 | 06:53 PM
skateparkdave's Avatar
skateparkdave
St. Jude Donor '05-'06
Default Re: 84 running like poop (vettie85)
Gut that Cat!! Or remove it.. If you in an emmission friendly state that is :thumbs: Could be number of thing though..if it started all the sudden check vaccume lines and ingnition systems. Oh yeah, dont forget fuel pressure..
[Modified by skateparkdave, 5:59 PM 5/25/2004]
[Modified by skateparkdave, 6:01 PM 5/25/2004]
Old May 25, 2004 | 06:56 PM
rick lambert's Avatar
rick lambert
Default Re: 84 running like poop (skateparkdave)
By all means-replace that filter first ;)
Old May 26, 2004 | 03:44 AM
ben73's Avatar
ben73
Default Re: 84 running like poop (rick lambert)
If a new filter doesn't fix it, check the fuel pressure.. 84 fuel pumps are known to be marginal and if yours is 20yo, its bound to be reduced in output.
Old May 26, 2004 | 09:58 AM
elkabong's Avatar
elkabong
Default Re: 84 running like poop (ben73)
Along with the fuel pump/filter also check the ignition. Cap, Rotor and module. I had a similar problem right after I got my 84 and the ignition components were toast.
To 84 running like poop
