I found a fuel leak from the schraeder valve fitting on the fuel rail of my 88. Its leaking from the core of the fitting, not where it meets the rail, so I need to replace the fitting itself. Does anyone know a pn, gm or otherwise, for thise piece. I'd like to get the cap too for it, since mine's long gone, but that's not too urgent.
Guess that fitting couldn't handle the pressure the new fuel pump was puting out.
Re: Need a pn for a fuel sys part (okinawa86vette)
Oh, i found the official parts descriptions, but no pn. The fitting is listed as "conn, fuel pressure", the cap is "cap, fuel pressure conn asm" and theres a compression washer listed as "fuel press comp seal".
It looks like gm sells all three as group 3.330, but I don't know how to translate this to a valid pn.
Perfect, just what I needed. Dealer wanted 35 bucks for it, but I guess it's better than a gas leak. None of the salvage yards around here wanted to split it from the rail cause then they couldn't sell it complete. And the dealer actually had one locally.
Chris
That's why I said "pucker up" I had priced one, because I wanted to add a Schrader valve to my Crossfire, to ease fuel pressure checks. I ended up buying a tire valve with a 1/8th" NPT thread, exactly what I needed for the "T" I had installed in the hard line. It cost about $6.00.
