Holy cow!!
Old May 26, 2004 | 10:00 PM
HeaderDesign.com's Avatar
HeaderDesign.com
Default Re: Holy cow!! (ski_dwn_it)
If you are looking for a way to rough-in the throttle body or carburetor size, you can use these equations for performance applications:
CFM=1.7xHP for carbureted applications
CFM=2.0xHP for port fuel injected applications
Mass air flow shows up as engine power, so engine size and RPM and VE aren't needed in these approximate equations.
Old May 26, 2004 | 10:12 PM
Hole-Shot's Avatar
Hole-Shot
Default Re: Holy cow!! (jerkyboy)
I'll wait for the track results. Good luck Jesse.
Hey JerkeyBoy...Love that hardtop !! :thumbs: :cool:
Old May 26, 2004 | 11:09 PM
Vic'89's Avatar
Vic'89
Default Re: Holy cow!! (Hole-Shot)
Exactly. Good luck Jesse.
Vic
Old May 27, 2004 | 01:32 PM
Ramanstud's Avatar
Ramanstud
Raman,
I would not draw that conclusion, IN FACT, I would say that for 95% of the setups here 58mm is more than enough.
I was actually referring to the 48mm STOCK unit... but I get what you mean. :thumbs: I'm in the position of trying to justify a 52mm (bored stocker) throttle body at the moment, but I just seem to read so much conflicting information on how good the stocker is vs larger units, etc....
With my heads, cam, stroker and SR setup I imagine a 52mm will pay off then. :yesnod:
Old May 27, 2004 | 02:52 PM
ZylaRace's Avatar
ZylaRace
Default Re: Holy cow!! (Ramanstud)
I consider the calculations to be a good place to start. They would tell the story if the engine were pumping fluid instead of a gas. i.e Fluids don't compress, (w/o a phase change), gases do,... passing thru tubes, blades, obstructions, etc.
I don't consider VE's to be something you can calculate ahead of time. It usually comes into play, "as a result of". Put another way,... use a combo that works well together. The final part of this usually comes down to, "give it a try". (Just like tuning.)
Just my $.02
Jesse, I'm surprise you picked up as much as you did. i.e. I would have bet (heavy) against that mod. Good find.
