Horn won't blow
May 26, 2004 | 01:01 PM
Horn won't blow
:party: Both horns on My 90 don't make any sound. Could it be the relay or
or has anybody experienced other causes
May 26, 2004 | 03:36 PM
Re: Horn won't blow (ringleader90)
my horn sounds like the last noise a dying old emphysemic goose would make on its death bed. it is actually fairly embarassing to use it...
Cruise-In II Veteran
Set the security alarm with the window down; reach in and unlock the door and open it. If the alarm sounds the horns check the horn ring.
If the horns don't sound, tap a jumper to the power connection of each horn; if they shound check the horn relay behind the center of the I/P in the mulit-use center.
May 26, 2004 | 04:03 PM
Re: Horn won't blow (65Z01)
how do you check the horn ring
May 26, 2004 | 04:05 PM
Re: Horn won't blow (amswak)
A friend has 89 Vette and he had the same problem and sprayed the horns with wd40 and that fixed it :smash:
May 26, 2004 | 04:35 PM
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
:lurk: This can't stay serious for too long....
[Modified by JrRifleCoach, 1:35 PM 5/26/2004]
May 26, 2004 | 06:04 PM
A horny one will! :lol: :lol: :auto:
May 26, 2004 | 06:35 PM
I just poped the horn button on my '88 and cleaned the contacts but that air bag on your '90 may make it a little more of a challenge.
May 26, 2004 | 08:02 PM
May 27, 2004 | 12:22 AM
I had a case where the bayonet connector was not making perfect contact, and my horns didn't work only when the wheel was straight. Strange. (The connector is a spring loaded connector on the horn switch harness.)
Here's the post that describes this in a bit more detail.
http://forums.corvetteforum.com/zerothread?id=785963
:cheers:
May 28, 2004 | 08:37 PM
:cheers: Horns blow now :D Thanks to everyone for your input!!
May 29, 2004 | 09:48 PM
great! so what was it?
May 29, 2004 | 09:56 PM
Re: Horn won't blow (tempest)
:smash: There is a wire that goes into the steering column with a spring on the end of it that goes into a cam that is made out of plastic. The sping is always under tension and the cam broke. Had to pull the air bag and steering wheel to replace the cam.
