tune up options!
Here is what all i'm having done
1 Optil
2 plugs
3 plug wires
4 water pump
5 thermo stat
6 serp belt
any ideas guy, the car is running fine, just doing preventive maint. BTH i have a 1996 Lt1
As to the opti and waterpump, if the car is running fine that is going a little crazy on a tune up. My '93 opti lasted me until last year(upped the rev limiter) and I'm still using the original waterpump. You might just try all the rest of the stuff and wait on the opti/pump until you need them. It seems that once they get replaced the first time they start failing all over the place. You have the good opti anyways, save your money.
You don't need to pull the cover in order to do it.
Take a look at you PS hose, it easier to replace when everything is apart.
