L98 vs LT1 Thermostat temp question
where as a LT1/LT4 has OEM a 180 deg thermostat? now regarding the LT1's thermostat what benefit will occur from installing a 160 deg thermostat being were only talking about a 20 deg difference? wouldn,t it be more benefical to just have the cooling fans start at a lower temp?
thanks boonie
a 180 thermostat in an LT1 is pretty darn close to 195 degrees in equilibrium. in high speed low load situations, where the coolant entering from the radiator is very cool, the thermostat can overcompensate.
for instance, my car with the fans on full blast and the stock stat would run right around 195 degrees in traffic. but on the open road, even with the fans going full blast, it would run closer to 200 degrees.
check this out for more info:
http://forums.corvetteforum.com/zerothread?id=797977
-michael
If you go with a lower temp T-stat you also need to change the fan control to help maintain temps in slow traffic.
The T-stat sets the engine operating temp but sufficient cool air flow through the radiator is needed to maintain it.
BTW, the rule of thumb is that every 30deg drop in intake temp is worth ~10chp. On the early MAF engines the ECM used coolant temp to set fuel & spark advance, so CHP was quite dependant on coolant temp.
