Cooling fan question..
Old May 27, 2004 | 09:04 PM
JB666's Avatar
JB666
Default Cooling fan question..
When I was under the car tonight, changing the oil, I figured I'd stay under there, and check for leaks while it ran for a few minutes(up on ramps). I noticed that neither of the fans were spinning.. I thought one fan spun all the time, and the other came on at higher temps??
I'm sure this is wrong, but what's the cycle for fan#1??
And I'm SURE this is a :beatdeadhorse: subject!!
Old May 27, 2004 | 09:09 PM
LT-4 CE's Avatar
LT-4 CE
From: Everyday you must choose between the pain of discipline and the pain of regret. Fredericktown, OH
Default Re: Cooling fan question.. (JB666)
Not sure of the specific temps, but if I recall there are two stages to the fans, first on at about 220 (+or-) and the second on at 238??? I may be high, but I am pretty certain that one doesn't run all the time.
When I had my computer done, I installed a 160 thermostat and had the fans programmed to kick on stage 1 at 183 and the second I beleive is about 205. It has never been to 190 in the year since that has been done.
Old May 27, 2004 | 11:10 PM
jfb's Avatar
jfb
The main fan comes on at 228 F by the ECM. The auxiliary fan comes on at 238 F by a thermostatic switch in the left head between cylinders 1 and 3.
Old May 27, 2004 | 11:14 PM
BlkMagik's Avatar
BlkMagik
Default Re: Cooling fan question.. (LT-4 CE)
That sounds like a good idea, was that expensive/difficult?
Old May 28, 2004 | 02:30 AM
vettenut85's Avatar
vettenut85
Default Re: Cooling fan question.. (BlkMagik)
you can buy a cooling fan switch from ecklers or corvette central.i got the one that turnes on at 195 and off at 180,i also changed to a 180 thermostat,i wired the new switch into both fans, when both fans come on she cools down to 180 super fast.you dont have to get a new computer chip unless you are going that route anyway.
Old May 28, 2004 | 06:18 AM
LT-4 CE's Avatar
LT-4 CE
The thermostat was cheap ($15 or so) and easy to install. As a 1996, to reprogram my fans I had to reprogram the entire computer. I had http://www.pcmforless.com do mine and they did a very nice job - doing some other things as well. There are some forum members who seem to be getting rave reviews for the computer work they do as well. Ended up being about $200 to do the computer if I recall.
Old May 28, 2004 | 08:51 AM
LT4BUD's Avatar
LT4BUD
BlkMagik
Alaskan Daily Driver?????????
:crazy:
On your 86 you will need to change the chip to adjust fan turn on/off temps...different from 96 where you reprogram the computer...
[Modified by LT4BUD, 7:51 AM 5/28/2004]
Old May 28, 2004 | 09:56 AM
Strick's Avatar
Strick
Here is what I did as a way to control the fans: I found the ground wires that go to the ECM from the fan relays. Normally, the ECM controls the fans (using the sensors) by completing the ground and signally the relay to power the fans on. [also, the A/C when turned on, starts the fans] BUT at 35mph, the ECM turns off the fans as they are not needed above this speed. Back to those wires I found, I put a switch for each fan in my cockpit (under the ash tray lid) so I can turn on the fans when in traffic or slow cruising without turning on the A/C. BUT, I have to remember to turn them off above 35mph as I by passed the ECM control of the fans with the switches on. I just love switches. Along with the electric water pump I have, I can cool the engine rapidly after shutdown by just turning the key on and switching the fans on. :cheers:
Old May 30, 2004 | 12:58 PM
BlkMagik's Avatar
BlkMagik
Default Re: Cooling fan question.. (LT4BUD)
BlkMagik
:crazy:
You know it! It handles better than you would think on ice and snow. :thumbs:
To Cooling fan question..
