Dead opti, can I dry it?
Old May 27, 2004 | 11:34 PM
Scott Muharsky's Avatar
Scott Muharsky
Default Dead opti, can I dry it?
I have many vehicles so I never drive my vette in the rain. My opti is supposedly dead, can I just dry the poopie out of it with a hairdryer and be on my merry way? Please?
Old May 28, 2004 | 12:03 AM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Default Re: Dead opti, can I dry it? (Scott Muharsky)
You might be that lucky, I'd never be!
Old May 28, 2004 | 12:07 AM
Scott Muharsky
Default Re: Dead opti, can I dry it? (Corvette Kid NC)
Can it hurt to try?
Old May 28, 2004 | 12:09 AM
Corvette Kid
No, I don't think a hair dryer will get hot enough to hurt anything.
Old May 28, 2004 | 01:43 AM
kman0066's Avatar
kman0066
The moisture itself being in there is not the problem. The problem is when the moisture creates rust or the moisture creates a short. Either way, once this happens, it's ruined. Now, if you get it wet and dry before you try and start the car, that my help but if you are having problems, the only thing that coud save it is possibly opening it up and cleaning the inside but that is a small chance in you know where.
Old May 28, 2004 | 09:16 AM
Strick's Avatar
Strick
Hi Scott, How many miles on the 92? My original opti made it to 44K when my OEM water pump leaked all over my opti and destroyed it. Bite the bullet and replace the opti and water pump (I chose the electric water pump route). Also vent the opti like the 95 -96 LT1's.
Here is some lite reading for you.
https://www.corvetteforum.com/techti...=231&TopicID=2
[Modified by Strick, 9:18 AM 5/28/2004]
To Dead opti, can I dry it?
