How to remove balancer bolts?
Old May 29, 2004 | 10:13 PM
VenkmanP's Avatar
VenkmanP
Default How to remove balancer bolts?
Working on opti replacement.
How do I prevent the crank from rotating when I try to remove the balancer bolts? If I had a M6 I could put it in gear, but the A4 just slips.
Old May 29, 2004 | 10:57 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: How to remove balancer bolts? (steve9899)
I first loosened the three outer bolts with the serpentine in place and just put enough pressure on it till I got these bolts broken loose.
When the center bolt would not budge with this method, I removed the serpentine and the three outer bolts and replaced them with long bolts from my blancer puller kit. Then I used the long bolts to get enough leverage with a pry bar to hold the balancer while I loosened the center bolt. I've also used this "trick" to rotate the crankshaft in reverse (which would loosen the center bolt).
Old May 30, 2004 | 12:22 AM
olman's Avatar
olman
Default Re: How to remove balancer bolts? (65Z01)
Strap wrench from Sears or similar might do it.
Old May 30, 2004 | 12:32 AM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
:lol:
Use the tool the PROS use: pneumatic impact wrench. (even if you have to rent one)
:yesnod:
Larry
code5coupe
:seeya
Old May 30, 2004 | 01:36 AM
VenkmanP's Avatar
VenkmanP
Second breaker bar on the hub-crank bolt did the trick.
Seems obvious now that I thought of it...
Old May 30, 2004 | 04:31 AM
BAM92's Avatar
BAM92
Shouldn't have to remove hub, just balancer to replace opti.
To How to remove balancer bolts?
