Ported Heads Intake for LT4
Old May 30, 2004 | 09:08 AM
LT4MOY's Avatar
LT4MOY
Default Ported Heads Intake for LT4
What do you guys think ported heads/intake and cam swap would cost? Parts/Labor? Just want to make sure I get a fair deal when I go in next week. Thanks. We got some really smart car geeks on here.
Old May 30, 2004 | 09:19 AM
LT-4 CE's Avatar
LT-4 CE
From: Everyday you must choose between the pain of discipline and the pain of regret. Fredericktown, OH
Default Re: Ported Heads Intake for LT4 (LT4MOY)
LT-4 BUD just did something very similar and from the sounds of things, made some big power. No clue what it set him back though. Maybe he'll see the post.
Old May 30, 2004 | 09:26 AM
STL94LT1's Avatar
STL94LT1
I paid around $2500 for my heads/cam upgrade, but I turned the wrenches myself.
A shop will probably charge around $4,000-$5000 for a turn key heads/cam upgrade.
Old May 30, 2004 | 10:40 AM
FD2BLK's Avatar
FD2BLK
AFR 195 CNCed LT4 heads $1795. LT4 Hot-Cam $135 (Just the cam, you already have the R/R's)
It can be done for less then $2000 for parts. As for labor it is going to be based on there rate per hour but just a stab in the dark i would suspect $1000-$1500 range
The reason I like the AFR option is they flow beter then most of the flow #s I have seen for ported stock heads and are around the same price. If you wan'ted to you can always sell the stock heads and get a few $$$$ back
[Modified by FD2BLK, 9:43 AM 5/30/2004]
To Ported Heads Intake for LT4
