Ignition Module
Old May 30, 2004 | 10:12 AM
vsocks's Avatar
vsocks
Default Ignition Module
I just went to install a new Accel Ignition module in my 84. Taking the old connectors off I saw something that may not be right. On the one side(toward front of engine) where the 2 pins connect there was a plastic piece loose underneath the wires. Is there suppoose to be a top part to this connector and it is missing? I was considering putting in a new DUI distributor but thought I'd try the module first. If this is not right maybe I will makje the switch now. What do you think?
